Old 08-10-2007, 11:15 AM   #1
2VO
Question How To Fix Boxter Problems
The problem I’m experiencing is the automatic window lowering when opening/closing driver’s door. The window drops 1/2” when lifting handle in process of opening door. The problem is the window lifts back up when the handle is released. Thus, when door is closing the window impacts the frame. Passenger door shows how it should work: On lifting handle window drops 1/2” and stays down when door is open and handle is released (thus when closing door window is in down position and does not hit frame). Does anyone know the likely cause of the problem and any ideas how to fix it?
2VO is offline   Reply With Quote
Old 08-10-2007, 11:30 AM   #2
Send a message via AIM to blinkwatt
It does that do to the convertible design of the car,it's not a flaw or glitch. As to what it's purpose is beats me.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 08-10-2007, 11:33 AM   #3
Send a message via Yahoo to Chills
He's saying that on the driver's side the window goes back up before the door is closed, ie as soon as the handle is released. The passenger side works properly, but not going up until the door is closed.
Sorry man, no idea how to fix it.
I bleed green
It's not about the summit, it's about the climb.
http://i133.photobucket.com/albums/q46/chills1138/2.jpg
Chills is offline   Reply With Quote
Old 08-10-2007, 11:39 AM   #4
Send a message via MSN to CJ_Boxster
As for the Window raising back up after opening the door, i would suggest looking at the Door Latch grabber... or whatever its called, Im talking about the part on the door that grabs onto the striker plate. That is suppose to send a signal to the window that states that the door is still open and for the window to remain lowered until the door is closed. Heres a good way to tell if its malfunctioning or not, Open the door, and with the door open, turn the engine on... if the interior dome light and door lights turn off, then the latch that grabs the striker plate is no good, because the lights should stay on when the door is open after the engine is started.
If it was working it would tell the window to stay down while the door is open and the interior lights would turn stay turned on if you start the engine and leave the door open.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 08-10-2007, 04:16 PM   #5
2VO
Wndow raising after opening door
I did as you suggested (turn engine on with door open), and the interior lights did not come on. Your diagnosis of the problem has to be right on. Now, how do I get to the microswitch on the door closing striker plate (or should I take it to the dealer)? I find nothing regarding this in the Boxter-S manual. Regardless, thanks Carlos for your insight in pinpointing the problem so that I can relate it to the dealer's service tech.
2VO
Old 08-11-2007, 05:11 PM   #6
husker boxster's Avatar
I had the exact same symptoms back in Feb. I was still under CPO at the time, so the dealer fixed it for free. They replaced the pwr wnd motor.
1989 928 S4 5 spd - black
Old 08-11-2007, 05:41 PM   #7
Send a message via AIM to djomlas
those were the symptoms on my car, before the whole thing just gave out and window dropped in the door...well actually it started acting up for a day, and then completely stopped.
new window motor was put on and its fine now. surprisingly its not that expensive at all
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
