As for the Window raising back up after opening the door, i would suggest looking at the Door Latch grabber... or whatever its called, Im talking about the part on the door that grabs onto the striker plate. That is suppose to send a signal to the window that states that the door is still open and for the window to remain lowered until the door is closed. Heres a good way to tell if its malfunctioning or not, Open the door, and with the door open, turn the engine on... if the interior dome light and door lights turn off, then the latch that grabs the striker plate is no good, because the lights should stay on when the door is open after the engine is started.
If it was working it would tell the window to stay down while the door is open and the interior lights would turn stay turned on if you start the engine and leave the door open.
