Old 07-17-2007, 03:31 PM   #1
Smoke Problem
I have the occasional smoke problem at start up but this is more serious. I track the car a PCA DE events and sometimes after a hard turn, I get a tremendous puff of blue white smoke from the exhaust. If I run hard enough to get the PSM to kick in, the problem gets worse. I was black flagged once. This has also caused a sensor to fail and I get the check engine light. The car is fine and still runs great even with the light on.
Any help would be greatly appreciated.
2003 Boxster S
Stewart is offline   Reply With Quote
Old 07-17-2007, 03:44 PM   #2
2003 Boxster S
When was the last time you had the spark plugs changed? I've seen that color smoke before come after a sparkplug had gone bad. What code did the check engine light give you?
porsche986spyder is offline   Reply With Quote
Old 07-17-2007, 05:13 PM   #3
Porsche "Purist"
Paul's Avatar
How full is your oil?
Are you using any oil?
Is your coolant clean and free of oil (no brown foam)?
Is you air/oil separator system in good shape?
1987 924S. 2002 996TT. PST-2
