07-14-2007, 09:06 PM
Uh-Oh (Scratch)
Story: While driving over a rather large speed bump, I was moving maringally faster than normal. I hear a crunching noise (DO'h). Under my car, it appears I have scratched up one of the low-hanging steel bars near the rear axle. Not a big issue since I can't see it without getting on my hands and knees, but will this spot be highly prone to corrosion? (roads = very salted in upstate NY)
07-14-2007, 09:13 PM
Porsche "Purist"
Be more worried about it being bent. I'd have it looked at.
1987 924S. 2002 996TT. PST-2
07-14-2007, 09:26 PM
With visual inspection, nothing seems to be bent. I drove the car a bunch afterwards and noticed no differences.
Is this going to pose a corrosion problems?
Also - worst case (pretend something is bent), what is the typical cost of a fix?
07-15-2007, 07:15 AM
If you are worried about rust, you could treat the area with a rust preventative. You could find those at auto-parts/hardware stores. What exactly hit on the underside of the car? I believe many suspension bits like the control arms are actually aluminum so rust may not be an issue anyway.
07-15-2007, 08:50 AM
Adam,
What I scratched was a low (probably the lowest) clearance part of the car. It looked like a tubular metal bar that attached itself near both of the rear wheels. It is the part with the white "made in germany" sticker. Do you know what part I am attempting to describe is?
Also, do you advise that next time I get the oil changed or new tires, I have them spray that area?
Thanks for the advice!
07-15-2007, 09:16 AM
looks like you scratched your sway bar.
even if oyu wanted to replace the whole part its not that expencive
my cardomain/pictures page
07-15-2007, 09:27 AM
This is what I like to hear  .
So bottom line - I scratched my 'sway bar' and it is not expensive to replace. As a result, I can let it corrode away and get scratched more and when it is in disgraceful shape, I can then inexpensively (relatively) replace it?
Also - from a parts+labor aspect, what do these things cost to place?
07-15-2007, 09:31 AM
I agree, sounds like the sway. You could probably get that treated/painted without removing it if care is taken to mask off surrounding areas. Ideally, it should be removed and painted or maybe replaced if it's more than just a cosmestic scratch. Depending on the hit it took, you may want to have a qualified mechanic take a look see and see if it was tweeked.
07-15-2007, 02:51 PM
It was a light hit and I don't think it is severely damanged. Do you know if the sway is steel or aluminum? I am more worried about the exposed surfaces corroding easily.
Also - got a rough guess as to how much it would cost to completely replace?
07-15-2007, 03:28 PM
They are steel. I'm not sure how much they cost, but I would definately avoid buying through the dealership. Try a search on google and see who sells oem sways for the boxster.
07-16-2007, 07:48 PM
Porsche "Purist"
Sway bars are pretty tough. If you are sure that's all that was hit, don't worry about it.
Post a picture and we can better help you.
07-16-2007, 07:54 PM
I have a rear sway bar from an 99' 5spd w/ bushings. Contact me if you want it for dirt cheap.
