05-25-2007, 11:25 AM
#21
Guest
I heard of someone putting header wrap around their mufflers and they said it helped the drone by about half. Might as well give it a shot.
05-25-2007, 11:41 AM
#22
wooah Can you find me some more info on that!! i will forever be in your debt thanks
05-25-2007, 05:43 PM
#23
Originally Posted by CJ_Boxster
I plan on making my own using borla mufflers, but it will be clamp on rather than welded so i can change mufflers in the future if i wish to.
Anyone know of any other muffler brands that will sound really good? I would like to get somethign that sounds like ferrari-ish
Boxster sound llike a ferarri? Not going to happen. Flat sixes and V-12's 10'sr 8's won't sound similar.
05-25-2007, 05:57 PM
#24
header wrap? here ya go:
http://www.jscspeed.com/index.html?/univ/thermotec.htm
or maybe you could try this "super sonic acoustical mat"
"This high quality mat offers superior sound dampening control to reduce road noise, rattles, engine noise, and any other noises that are bothersome. The high density polyethylene film with an aluminum foil composite is abrasion and tear resistant. The gray film provides structural integrity & strength, allowing the material to bend, move, & return to shape even under tension forces. The product is 70 mil in thickness, contains a high temperature adhesive backing, and is easy to trim & fit. The rubberized compound is applied with the high temperature adhesive to absorb all those out of control noises."
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
05-25-2007, 06:22 PM
#26
Originally Posted by Boxtaboy
Sounds kinda similar I guess. Where is a sound like that under 2k?
05-25-2007, 06:28 PM
#27
07 Carrera S Cab
Not sure because I don't know anyone personally that has that exhaust system. It is mucho expensive ($5000), but probably the most similar in sound to a Ferrari I've ever heard without having to buy one.
05-28-2007, 12:24 PM
#28
do you think the header wrap will reduce the droning in my car?
05-28-2007, 01:54 PM
#29
07 Carrera S Cab
Dude...sorry to say, but give it up already....NOTHING is going to work except you pulling out the muffler and installing a factory Porsche Sports Exhaust, modifying the stock muffler, or buying a Dansk pressed sports muffler. Those are the only exhausts that don't drone at all.
The design of the location of baffles and pipe length INSIDE the muffler is what cancels out the drone. Engineers spend a lot of time figuring this out, and your universal fit Magnaflow muffler cans are not designed specifically for the Boxster, so it will give off that annoying resonance. No matter what you do to the outside of the muffler, it will not help unless you wear earplugs.
05-28-2007, 02:18 PM
#30
Ditch that "Custom" exhaust system and buy the Fabspeed or Porsche Sport exhaust. It will be cheaper in the long run. By the time you wrap your headers and sound proof your firewalls and buy your ear plugs you will be at the cost of the Fabspeed. They guarantee no drone so if you get drone it's their problem to fix not yours.
http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags, BK Rollbar extender.
05-28-2007, 02:31 PM
#31
Cabin Droning Driving Me nuts!!!! SOmeone please come up with a solution, to allow to me both keep the exhuast and muffle the sound in the cabin
I hate to tell you, but it will likely get worse. It takes a little while to break-in your muffler - it will get louder over the next month.
05-28-2007, 03:32 PM
#32
Just go with straight pipes...
They sound amazing, they are loud!!
http://www.youtube.com/watch?v=M1VI-rTaUmU
This is a exhaust setup with the bypass pipes, have the guy who built that custom setup for you do this and change the tips to what you like.
http://www.youtube.com/watch?v=EEPv_l6GBfw
My favorite video with current setup.
This is me approaching from about 1.5 to 2 miles away.
You can hear the car at full throttle in the distance but i had to back off...i was hiting going way to fast for public roads.
There are a few other videos with the new set up in different situations.
http://www.youtube.com/watch?v=Pw9bRcdOj-Y
By the way right now the car has stock cats, aftermarket headers, muffler and a supercharger. There is another phase of mods that are more agressive than what i have now.
Have a great day,
gary
05-28-2007, 03:36 PM
#33
07 Carrera S Cab
gary
Gary, I don't doubt that the straight pipe set up sounds loud, but this guy specifically is looking to tone down the resonance/drone in his car, as it is driving him crazy. I doubt a straight pipe set up would help tone down the drone, no?
05-28-2007, 03:52 PM
#34
Magnaflows or most american brand mufflers=drone issue, plain and simple. Only way to turn it down is with Resonators(definitely wont work in most porsches bec. of the limited space) or replacing your mufflers.
IMO, the more highend european made mufflers are your best bet when you dont want the interior drone issue. I have a BRABUS exhaust with Resonator deleted in my MB E55 and there is absolutely NO drone even with the resonator delete mod.
05-28-2007, 04:15 PM
#35
The straight pipes where so LOUD i did not hear any drone, or my, cell phone, myself thinking....
The straight pipes where tounge in cheek, the other two options where realistic options.
The current setup i have has no drone, its actully to quiet for my taste and i may be looking for a used GHL.
The setup with the bypass pipes sounded GREAT but my tips where not the most attractive.
BTW Boxtaboy..i did get you wink. I love sarcasm.
Have a great day
05-28-2007, 04:34 PM
#36
07 Carrera S Cab
Have a great day
"...so loud that you didn't hear any drone or yourself thinking." That is too funny.
I've actually driven a GT3 with straight pipes before, and the sound ROCKED. Problem was it rocked the entire street so much that the neighbors came out to yell at me. LOL
05-28-2007, 05:46 PM
#37
the way i did my exhaust mod i dont have any drone in the cabin.
took it autocrossing this weekend with the guys, even more impressed and everyon gave me compliments on the sound.
plus it cost me under 50 bux
and i can close it, making it 100% stock sound wise, or open it partially.
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
05-29-2007, 04:16 AM
#38
False.
It has nothing to do with the country of origin of the muffler. It has everything to do with the construction of the overall exhaust system. The factory system is extremely complex, with tuned chambers and absorptive materials to cancel specific frequencies. The cheap custom exhaust that a local shop can build you doesn't have these designed-in features, so in the case of a Boxster it will create unpleasant tones. Simple as that.
Fixing the problem is far more complex. But it has nothing to do with the mufflers being "Amiercan."
05-29-2007, 06:18 AM
#39
Guest
All I said was I saw where a person on a website with an aftermarket exhaust wrapped header tape (or some other varient) around the 2 mufflers. He said it helped. I would believe it due to the absorbing properties of the tape changing the resonant frequency of the metal. Do I know for a fact, no. But try it... you got nothing to loose but a couple bucks.
06-06-2007, 11:46 PM
#40
Where,
Since you live in the same city as I do, and may not mind visiting my facility in Chino, feel free to stop on by, so that I can take a look at your system. I may have a solution for you.
I just made a custom prototype unit that does not have the problems you have encountered...nonetheless, I am curious to your DB level with the current setup. Let me know!
Bisimoto Engineering
2001 modified Boxster S, slate grey, red interior
