05-16-2007, 05:35 PM
#21
There Is No Substitute.
I've got the same one as, djomlas. So that one is just bolted on over the original?
Nice license plate!
05-16-2007, 05:39 PM
#22
07 Carrera S Cab
Yes...that's what I've been trying to explain all along.
Look closely inside your tip, and you'll see the original oval tip hiding behind it.
You will not be able to convert that to a dual pipe look unless you change your whole exhaust out, unfortunately.
05-16-2007, 05:41 PM
#23
Just for laughs, here is a pic of the 03 S exhaust on my 01 S
These are the bolt on tips.
05-16-2007, 05:45 PM
#24
07 Carrera S Cab
[QUOTE=Marc Gelefsky]Just for laughs, here is a pic of the 03 S exhaust on my 01 S
Yeah, but don't confuse the guy more!  That is the 03 exhaust with the 03 dual tips put on your 01 car....not an 01 exhaust with bolt on 03 tips.
05-16-2007, 05:47 PM
#25
[QUOTE=Boxtaboy]
What was that middle part again?
05-16-2007, 05:50 PM
#26
yeah the one that i have is bolted on, 2 screws and brackets
my cardomain/pictures page
05-16-2007, 05:51 PM
#27
07 Carrera S Cab
Aarrggggghhhh!! Ahhh fuhgettaboutit!
05-16-2007, 06:00 PM
#28
It's a '99. But interestingly enough it has a bolt on tip. It has got two screws on each side. So bmwm750, pm me a picture.
If you have a 1999 with a chrome tip held in place with set screws then this is it. I was an option that slid over the existing oval tip. That has nothing to do with the bolt on tips from 2003-2004, as there was a muffler change 2003-2004.
If you want 2 tips then you need to get another muffler. The number of tips is a cosmetic issue.
05-16-2007, 06:58 PM
#29
Thanks everyone, I got it figured out. I have the stock '99 exhaust with a welded tip and a chrome cover bolted over it. The '03 and newer boxster exhausts have tips that can be changed. And I cannot change to a dual exhaust unless I replace the whole exhaust system.
Correct?
05-16-2007, 07:15 PM
#30
Correct?
You are correct sir!
05-16-2007, 07:20 PM
#31
07 Carrera S Cab
Correct?
Yes, you cannot change to dual tips on your exhaust unless you change the muffler.
05-16-2007, 10:47 PM
#32
Uhh... Im not so sure about that. As I said, I cut off the original tip and welded on a new one. If someone can show me a picture of a bolt on tip I can tell you if it can be cut and welded on to a 99 muffler. Like I said, I cut my new tip up to make it fit.
05-17-2007, 03:34 AM
#33
07 Carrera S Cab
Ok...Correction- you cannot switch to a dual tip on your car unless you switch out your muffler... OR, if you are as resourceful as Boggtown, and know how to cut and weld metal.
05-17-2007, 06:10 AM
#34
yeah if you have a velder you can slap on any tip you want.
05-17-2007, 07:12 AM
#35
Originally Posted by Boxtaboy
@porsche986spyder: The oval chrome tip you have goes over the existing oval tip welded on your muffler. The 03+ tips will not bolt onto your pre-03 muffler, because these tips are made to be bolted on the 03+ mufflers that have no tips welded on already.
Well the guy rick3000 never told us what year his car was. I was assuming he had an earlier model.
05-17-2007, 07:14 AM
#36
The oval stacked one also will not fit on a pre-03 muffler, as they do not fit over existing tips...they fit on 03+ mufflers with no tips welded in place.
Not according to PORSCHE web site. Says date 8/02 and up. So if you have an 02 you would be okay.
05-17-2007, 07:22 AM
#37
But, don't forget, Porsche986spyder, soon after August 2002 Porsche started making the 2003 model year...I would guess.
05-17-2007, 07:27 AM
#38
07 Carrera S Cab
Exactamundo!
05-17-2007, 07:40 AM
#39
Exactamundo!
Makes sence. That's why it's always good to buy the next years model at the end of the year. You get nice upgrades.
05-17-2007, 08:03 AM
#40
like getting an 08 model this year...
i still dont see how the stacked ones wouldnt fit on the earlier models tho, like 98 99...
