Originally Posted by rick3000
I've got the same one as, djomlas. So that one is just bolted on over the original?
Yes...that's what I've been trying to explain all along.
Look closely inside your tip, and you'll see the original oval tip hiding behind it.
You will not be able to convert that to a dual pipe look unless you change your whole exhaust out, unfortunately.
