Originally Posted by boggtown
Uhh... Im not so sure about that. As I said, I cut off the original tip and welded on a new one. If someone can show me a picture of a bolt on tip I can tell you if it can be cut and welded on to a 99 muffler. Like I said, I cut my new tip up to make it fit.
Ok...Correction- you cannot switch to a dual tip on your car unless you switch out your muffler... OR, if you are as resourceful as Boggtown, and know how to cut and weld metal.
