Old 03-17-2007, 04:38 PM   #1
Unhappy Dash Guages not Working
I just started my cars after 5 months (2003 Boxster S). The dash guages are not working. No RPM, Fuel Level, Temp. or dash lights. Suggestions? Before storage I added the rear speaker kit and air horns behind the front bumper (wired to factory plug in front trunk). Everything else seems to be working fine, it started right up with no issues I just hope I don't have to take it in before I can even really drive it.
Happy St. Paddies Day
thanks
tom
buster356 is offline   Reply With Quote
Old 03-17-2007, 05:26 PM   #2
Try turning the ignition key back some..... the ignition switch could be at fault.
wvicary is offline   Reply With Quote
Old 03-17-2007, 06:25 PM   #3
Check your fuses.
Old 03-18-2007, 09:46 AM   #4
Smile
RandallNeighbour, THANK YOU! I reset all the fuses and everything is back to normal. I don't know which one it was but it works.
wvicary ignition had no play so then I went to the fuses, Thanks for the suggestion.
tom
Old 03-18-2007, 03:49 PM   #5
Glad you got it sorted but what do you mean you reset the fuses?? Did you find one that was blowen.
Old 03-18-2007, 04:31 PM   #6
I took every fuse out then put it back in, I didn't find a single blown fuse. I can only think one must have come loose when I was cleaning the car for the winter.
Old 03-18-2007, 04:47 PM   #7
Could have been that pulling a fuse caused something to reset?
Anyway, glad to hear it was a simple fix. I work on servers and sometimes, pulling things out and putting them back in fixes things!
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
Old 03-18-2007, 08:52 PM   #8
The contact probably got a little corroded and pulling, reinserting it rubbed it off enough for an electrical contact to be made...
Happy Motoring!... Jim'99
