Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster & Cayman Detailing Discussion
Old 05-11-2019, 12:20 PM   #1
thermostat issues?
Hi
Has anyone had problems with the thermostat showing red light Even though there is enough cooling water?
gabba76 is offline   Reply With Quote
Old 05-11-2019, 05:29 PM   #2
Motorist & Coffee Drinker
78F350's Avatar
Exactly what is the light doing? Steady on, blinking slow, blinking fast?
Read this:
Four functions of the coolant warning light:
1. Engine coolant level too low
— light flashes slowly (0.5 Hz)
2. Engine compartment temperature too high
— light flashes slowly (0.5 Hz) (engine compartment blower might be faulty)
3. Engine coolant temperature too high
— light is lit; pointer on the right
4. Temperature sensor at water outlet faulty
— light flashes rapidly (1 Hz); pointer on the right
Note
The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously
(1Hz = 1 flash per second. 0.5Hz = 2 seconds per flash)
Old 05-12-2019, 07:08 AM   #3
1998 Boxster Silver/Red
Originally Posted by gabba76 View Post
Hi
You might have better luck posting in the proper forum category.
This is the Boxster and Cayman Detailing Discussion forum. Try the "General Discussions" forum.
1998 Porsche Boxster
Old 05-12-2019, 08:14 AM   #4
2003 S, Arctic Silver, M6
paulofto's Avatar
Sometimes the simplest thing is the answer. Make sure your coolant cap is not cross threaded and make sure you have the latest one ending with 04 in the part number.
HTML code is Off
