Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster & Cayman Detailing Discussion
Old 11-19-2015, 12:00 AM   #1
kenand1988's Avatar
Preventing chips on front bumper from getting bigger
What are my options here? I have two silver dollar sized spots on the front of the bumper where the clear coat has completely separated and flaked off. It leaves an unsightly halo around the spots where you can see the clear coat continuing to separate. Car washes seem to be making the spots bigger and bigger. First off, has anyone had their front bumper repainted and could tell an honest price to expect. (you can PM me). Is there something I can do, that doesnt look hideous, to at least temporarily stop the size of the spots getting bigger? Also have a spot on the driver side mirrior, on the front of it.
Current:
2001 Porsche Boxster
Past:
2001 Toyota Celica, 1997 Miata, 1999 323is,
1995 Toyota Pickup, 1997 Subaru Legacy
kenand1988 is offline   Reply With Quote
Old 11-19-2015, 01:12 AM   #2
still plays with cars...
BoxsterSteve's Avatar
You are likely looking at a respray. I've had a clear coat only respray done once, and it worked well,but the car was less than 2 years old and had no road rash that would telegraph through the new paint.
I'd count on $500-700 for a quality job.
Six speed 2000 Boxster S
Old 11-19-2015, 04:32 AM   #3
It really depends a several factors. There's really not an attractive way to stop the flaking. I've seen folks apply the 3M clear film before, but it's not a long-term fix.
Regarding the cost of repainting, if you can remove the front bumper cover yourself, you'll save a lot of money. If you just want an average fix, take it to one of the national chains. If you want a quality job, take it to a well known independent shop. Painting could range from $200 - $600 I would think, depending on the shop and quality of labor/materials.
1998 Porsche Boxster - Ocean Jade Metallic
1985 Porsche Carrera Targa - Guards Red
1978 Porsche 911SC Euro Non-Sunroof - Grand Prix White
Seadweller is offline   Reply With Quote
Old 11-19-2015, 05:37 AM   #4
Motorist & Coffee Drinker
78F350's Avatar
I pretty much concur with Seadweller. The cost to repaint will vary a bit, but here, its $300-$500 depending on how much prep is needed and how much you shop around.
On one of my old Hondas, I feathered the clear coat back and resprayed it. It looked good from about 10 feet and was starting to peel again in about 6 months. Keep in mind that if you try to mend it yourself, you could end up making it more work for a pro to refinish later.
Old 11-19-2015, 05:40 AM   #5
Not much to do except a respray.
I cringed when you menitoned taking it thru a car wash, I would never recommend taking any car, other than a beat up thing, thru any car wash, okay a hand car wash would be acceptable, but machines Over My Dead Body/
Old 11-19-2015, 07:50 PM   #6
kenand1988's Avatar
Thanks for the input, consensus seems to be right around 500. Its a long shot but does anyone have any suggestions for a paint shop near Phoenix? I can remove the bumper and the little inserts myself. I've already done it before. I can sand it myself too but I think I should let a pro do it.
I'm leaning towards cost effectiveness so maybe a national chain, but I'm worried they won't get the metallicness of the paint right. How good are big name places? Is it truly worth spending another 2 or 300 dollars to go to an independent shop?
Current:
Past:
Old 11-19-2015, 08:01 PM   #7
If you don't care what it will look like take it to.maaco. If you want it to look flawless then a top local place is where you want to go.
If you take your boxster through an automatic car wash, you need to stop. If nothing else for the top which is not designed to deal with high pressure soap getting into the canvas.
Old 11-19-2015, 09:58 PM   #8
kenand1988's Avatar
Hm, I'm kind of stuck then... I use a conditioner on the top to hopefully nullify going through a car wash but out here in the desert our water is really really really hard, so using a garden hose to wash the car would be terrible for the car and im not an eccentric rich guy whose gonna buy gallons of water purely to dump on my car.
Current:
Past:
Old 11-20-2015, 04:48 AM   #9
If you don't mind the initial investment, you could address your water problem with one of these (or similar):
Spot Free Water Softener for your Boat
Old 11-20-2015, 06:26 AM   #10
No self service car washes by you? The old fashioned kind with the coin and the wand?
I use optimum no rinse wash. You can get it on amazon. All you need is a five gallon bucket with two gallons of water, a wash mitt and some microfiber drying towels. No hose needed. I have a hose and I don't use it because the no rinse stuff is easy and looks great.
Old 11-20-2015, 09:13 AM   #11
On the slippery slope
JayG's Avatar
Don't even need the bucket and water
Get a 1 or 2 gallon pump sprayer from Home Depot or Lowes. Do the mixing in the sprayer. Just do a light spray on the car, wipe with a microfiber towel and dry. I sometimes do 2 wet/wipe processes and then dry. I use 1 -2 quarts to wash the car and virtually no water on the ground. You can easily do it in your garage
With the 2 gallon sprayer, I get 6-8 washes per fill up
They make 2 versions of Optimum NoRinse
Blue - Wash and shine
Green-Wash and Wax
I use the green, they add a little carnauba wax to their mix
You can also mix it to use as a clay lube or detail spray
2004 996 Targa Tip
Instructor - San Diego region
Old 11-20-2015, 10:59 AM   #12
78F350's Avatar
I recently started using 'Meguiar's G3626 Ultimate Wash & Wax Anywhere Spray' on my helicopter at work and am getting some for my cars. Just spray it on and wipe with a microfiber cloth. It cleans off the bugs pretty well and prevents them from sticking so much in the first place. Also helps cut down on soot build-up behind the exhaust. No water needed.
Old 03-24-2017, 09:24 AM   #13
Lew
So Blessed!
Lew's Avatar
I never use water from a hose on my car. I do all the cleaning in my garage where it stays and under a cover. I don't drive it in bad weather. I will clean the outside at times using my duster first over a fender, etc., then with water in a spray bottle wet a microfiber towel and wipe down the area. After that I will spray on Mother's spray wax and buff with a clean microfiber towel...The paint looks like new!
I also never wet my wheels. Just wipe down and when needed, I use a small brush to do tire dressing. Normally about a hour to finish the job. The cars paint has no spider webbing!
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
Old 03-24-2017, 10:51 AM   #14
Optimum no rinse is pretty good stuff. Water alone will not provide enough lubrication between your paint and the microfibre to prevent marring the finish so its important you use some sort of waterless/rinseless wash product. Just remember to always use a clean portion of the microfibre when you're wiping. You'll probably go through several. If your car is really dirty, its always best to rinse it with water first.
Everything you would need to know can be found here:
Auto Detailing Facts, auto detailing Tips, How to detailing Guides, how to polish, how to wax, DIY detailing, do it yourself guides
Old 03-24-2017, 06:49 PM   #15
Originally Posted by boxxster View Post
Be aware that auto geek forums are moderated to basically only promote shilling for the products sold by autogeek. Autogeek will remove content (e.g., delete threads) promoting products not sold by Autogeek, which compete with AutoGeek-offered products.
Personally, I would recommend looking elsewhere besides autogeek for more unbiased detailing "facts" and "how to guides"... find a resource that is less biased.
But back to the (very old thead!) topic at hand - yeah, Optimum no rinse is good stuff. Makes a very economical clay bar lubricant, too.
2001 Boxster
Old 03-24-2017, 07:36 PM   #16
Agreed. I've actually never bought anything from there. The how to guides I linked to are very useful though.
Old 03-26-2017, 01:48 PM   #17
Porsche "Purist"
Paul's Avatar
Not long ago I took off the rear bumper cover of one of my cars and took it for estimates at a couple of good shops. They all said they would not do it unless they had the car to insure the paint would match.
Since driving the car without the bumper/license plate is not a good idea, taking it off was a waste of time.
1987 924S. 2002 996TT. PST-2
Old 03-26-2017, 02:19 PM   #18
07 Carrera S Cab
Boxtaboy's Avatar
Just give them a piece from the car that is painted, and they can still match it. For example, when I wanted the shop to paint my side skirts, I just gave them one of my painted bumperettes to use for the paint match. It came out perfect. For a rear bumper, I'd just remove the painted lid from my rear spoiler to match with.
Old 03-26-2017, 05:37 PM   #19
I need a front bumper and mirror respray. In the meantime - I found that replacing the mirror was cheap and easy and just bought a replacement. The mirror swap was easy and cheaper then any respray. So shop the respray of the bumper and look to Woody for a new mirror.
"YouTube Certified in Various Specialties"
Old 04-09-2017, 07:37 AM   #20
Lew
So Blessed!
Lew's Avatar
Clear Film
Anyone have the clear film paint protector installed on their Boxster? My front Bumper has a few rock chips on the lower half and I am thinking about having the Lumar clear film installed now on my Hood, Lights, and side Mirrors. I would like to install it on my bumper but not before having the paint chips removed. The Lumar film is supposed to be the best, and I have heard if a rock hits the film and puts a small depression in the film, it will heal itself. Not so with other films I hear.
HTML code is Off
