Originally Posted by 01986
the car is completely stock now... so I should be fine by using spacer? I've seen
ppl put turbo twists on their cars... I think the spec for front is 18 x 8 with et50
and rear 18 x 10 with et 65... can I get away with spacers with this setup?
thanks guys!
That's what I have on my car, 18x8 in front and 18x10 in the rear. No wheel spacers. But you could still add them. The rear would stick out further than the fenders. If you use the 18x10 in the rear you will need to change your rear tires. But the stock tires will fit also, just will not cover the width as good as a wider tire would. I think I have 285/30/18 in the rear. At first the stock 265/30/18 that I had were on, but there was a 2mm lip that was hanging off the rim. Stock tires are not wide enough. Hope this helps.
