The clearence issue is at the inner rim lip at top dead center. It was rubbing on the spring. With the 7 MM spacers, it clears the springs by 2mm. Very close. So I dont want to spend the money and buy the spings, coilovers, or the ROW setup, have it installed, and then find out I need new rims.
The next size spacer is 14mm and I dont want to use that much of a spacer.
James
2002 S
