Originally Posted by shuiyuan
sorry for my bad english, ok, i modded your pictures, my car is runing at where the circle at please see it and tell me that is normal or not. thanks!
That's a little on the warm side, but not 'overheating' yet. On your drive, are you stopped in a lot of slow moving traffic, or are you driving at good speed? Air flow through the radiators is better when the vehicle is moving, also higher engine speeds mean the water pump is pumping more water, thus moving more heat from the engine.
Have you removed your front bumper skin and cleaned out the radiators? Is there a good amount of fluid in your system? (check the tank in the back trunk with the engine cool, add more if needed)
If everything checks out, you might want to have an independent Porsche mechanic flush your coolant system. There might be blockage somewhere.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
