Old 05-06-2007, 05:23 PM   #1
docdyh
Has anyone retrofit 2003 OEM glass top?
Has anyone done this? I assume the OEM glass window is larger than the aftermarkets with better clearance for service position since the frames are different? Is it as simple as the porsche tech says?
Question:
You mentioned in an earlier reply that an 03 top could be mounted in a 99, and that one could be taken from a salvaged 03 and bolted into a 99. What needs to be taken from the 03 that is different than the 99?
Answer:
Should you be getting a top from a salvaged car then just un-bolt the complete top from the salvage car and bolt it on your car. The changes were to the top itself.
Scott Slauson - PCA WebSite - 5/6/2007
docdyh is offline   Reply With Quote
