Originally Posted by aussieboxy
So there will be no significant difference in braking performance with an upgrade? So why do they put bigger brakes on faster cars? The brakes on a 997TT are huge when compared to a 997 Carrera.
i upgraded to S brakes on my car. HUGE difference. the only real differences up front are larger rotors & pads. in back, the difference is thicker rotors. the brakes are much easier to modulate, allowing consistently shorter stopping distances. at the track, my fade problems were solved.
for the upgrade, you can really skip the rear. just do the front calipers, pads and rotors. they bolt right up. buy cross vented rear rotors and you're all set.
