Originally Posted by MNBoxster
How are you measuring your lateral acceleration? You're throwing around numbers here (both Baseline and Modified) which are greater than those repeatedly published for the Boxster S (0.91g).
While that may be so of a Modified Car, I doubt it's the case with a Base Boxster. I suspect your Data Logger is miscalibrated. How else do you explain it?
logger is not miscalibrated. it's a racepak gps; the accelerometers and GPS calcualted lat G's are the same. it's easy to explain:
1. modified car
2. turns 1 and 2 are slightly banked
3. alignment of a stock boxster s sucks, not enough camber
