Old 04-23-2007, 11:42 AM   #11
insite
Originally Posted by MNBoxster
How are you measuring your lateral acceleration? You're throwing around numbers here (both Baseline and Modified) which are greater than those repeatedly published for the Boxster S (0.91g).
While that may be so of a Modified Car, I doubt it's the case with a Base Boxster. I suspect your Data Logger is miscalibrated. How else do you explain it?
logger is not miscalibrated. it's a racepak gps; the accelerometers and GPS calcualted lat G's are the same. it's easy to explain:
1. modified car
2. turns 1 and 2 are slightly banked
3. alignment of a stock boxster s sucks, not enough camber
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
