Originally Posted by pompous
This is gonna sound ridiculous...How do you manually raise the spoiler?
With the car turned on and at idle (or just twist the ignition key until the dash lights come on), look down at your fuse box cover near the dead pedal. There is a little rocker switch there. Press the upper part of the rocker switch, and the spoiler will raise. To put it down, keep the lower part of the rocker switch pressed for about 3 seconds, and it will retract.
