Old 04-05-2007, 08:03 AM   #7
Bob O
Originally Posted by c-c
I just got a set of H&R wheel spacers 7mm in the mail and they look completely different than any I have installed.
They are hubcentric and came with 2 bolts each. The spacers have a coutner sunk hole where one of the bolts goes, but it's short. Also didn't come with wheel bolts.
I haven't had the wheel off yet so not sure how to install.
Anyone have any pictures, or can anyone help link to a how to guide?
I'm assuming i need 7mm longer wheel bolts??? and 7mm longer lugs.
Any advice would be greatly appreciated.
-c
THe counter sunk hole is, for lack of a better term, to temporarily, hold the spacer to the hub so you can mount the wheels. When you place the spacer on the hub, rotate the hub until the hole lines up.. it will be obvious when you get there. The five main bolts, of course, actually hold the wheel to the hub with the spacer sandwiched between them. Without the small bolt holding the spacer to the hub, it would be nearly impossible to mount the wheel, since the spacer would turn and you'd have difficulty lining up the bolt holes
You'll need longer bolts. I don't know where you bought your spacers but wherever it was, they should have them. I bought my spacers and bolts from Paragon. Email or call and ask for Jason, who was great to work when I was shopping for them.
The longer bolts I've seen, and the ones I purchased, come with the cones already attached, making removing them from the old bolts unnecessary.
Hope this helps
Bob
79 911SC Targa.. gone but not forgotten
2001 Boxster Black/Savanah Beige
RoW M030 suspension
7/15 mm spacers
Deambered
Desnorked
SS door sills
Debadged
Clear tails
Technobrace
Technobra
I'll never own another black car!
Bob O is offline   Reply With Quote
