Old 03-04-2007, 04:37 PM   #1
porschegeorg
replace your spark plugs
I just replaced the spark plugs this weekend. I thought it would be more difficult than it was. For anyone who changes their own oil, changing your spark plugs is not a bad do-it-yourself task.
Tools: 5mm hex socket (or allen wrench), 8 inch socket extension, 10mm socket, spark plug socket.
Here is what I did:
1) remove the rear wheels
2) remove the wheel well cover (use a 10mm socket on the 2 nuts). I found it easier to reach the plug closest to the front of the car with the cover removed.
3) there are 3 plugs on each side of the engine. you can see the 3 coil packs with the rear wheels off of the car. remove the wire clip from the coil packs by pinching (with your fingers) the clip about an inch from where it attaches to the coil pack. there are 2 5mm hex screws that hold the coil pack to the engine. remove the 2 scews and pull the coil packs from the plug.
4) put the 8 inch extension and plug socket into the plug hole and fit it onto the spark plug. fit the socket wrench to the extension. (i found it easier to keep the socket wrench off of the extension and socket until i had them placed on the plugs). remove the spark plug.
5) put in the new plug in, attach the coil pack (be careful to keep the coil pack wire away from the coil pack itself when you are screwing it back on. (i managed to pinch one of my coil wires behind the coil pack when i was screwing it back on).
6) replace the wheel well cover
I also had to remove a clip (I think i was to an O2 sensor) in order to get to the 5mm hex screws for the plug closest to the front of the car.
All in all it took me a couple of hours to replace the 6 plugs, but I'm also not a mechanic by any means.
I used the original Beru plugs for the replacements.
2003 Boxster Seal Gray/Gray
TIP
5000 miles (for some reason I'm proud of this)
porschegeorg is offline   Reply With Quote
