			The hardware stores the VIN numbers, not the software.  You'd have to re-flash the hardware in order to wipe the VIN numbers.
As for buying cheap OBD-2 diags on eBay, a code reader is a little different than a datalogger, really.  You get a LOT more info out of these set ups than with a simple code reader.
Also, a code reader wouldn't give you your ignition counts or anything else Porsche-specific.  It would just give you what's available through OBD-2.
