Originally Posted by JFERR
ray986s,
When say low beams only with a plug and play, do you mean the high beams won't work at all or that the low beams will not adjust upward?
I'm getting the litronics and was planning on doing the plug and play because what's the point of doing all the wiring if all you get is the low beams adjusting upward 5 degrees.
That's correct it will not tilt up for the high beam. I did the wiring myself and it was very easy and it did not take very long. Even if you are not very handy, but can follow directions it will only take about 30 minutes... its worth wiring it up for the highbeam. I drive many dark roads and tilting it up for the highbeam really makes a difference.
986s sport design pkg, aerokit 1, litronics,deviating seat stitching, guards red seat belts, cf ebrake/shift knob,ssk, sport seats, hard top, full alpine system with 8" sub, mb quart speakers, Champion rg5, Eibach springs, sport exhaust, rear stess bars, custom ecu program, desnorkle intake, euro bumper, rear diffuser
