			ray986s,
When say low beams only with a plug and play, do you mean the high beams won't work at all or that the low beams will not adjust upward?
I'm getting the litronics and was planning on doing the plug and play because what's the point of doing all the wiring if all you get is the low beams adjusting upward 5 degrees.
				JFERRhttp:
Only problem with a Porsche is the traffic.
