Old 02-26-2007, 06:22 PM   #2
MNBoxster
Hi,
It could be any number of things like a Bad Plug, Bad Coil, Loose electrical connector to the coil, even leaky spark plug tube 'O' rings.
First, I'd change the plugs, especially if they're original, checking the spark plug and spark plug tube for Oil indicating the 'O' rings are bad. See if that doesn't correct it. If not, then suspect the Coil. All fairly easy stuff to check. Hope this helps...
Happy Motoring!... Jim'99
