Old 02-22-2007, 03:17 PM   #7
MNBoxster
Hi,
The One-Touch Window feature is not programmed by the Dealer, it's something you do yourself. The Service Manual states:
  • "Standardising the power windows:
    The system must be re-standardised after an interruption in the
    power supply to the power window electronics in the door. The position
    values for the short-stroke lowering function, position-controlled
    lowering function in the case of convertible top actuation
    and enabling for 'automatic start-up of window closing' (one-touch function) are redefined. The standardisation process is initiated by continuous actuation of the operating button [Raise window]. Hold down the button [Raise window] until the window isclosed and is switched off by the blockage detection function of the power windows.
And, you need to do this procedure to each window individually. Hope this helps...
Happy Motoring!... Jim'99
