Old 02-18-2007, 11:38 AM   #7
boggtown
Guest
Posts: n/a
The fact is, racing brakes squeel because they are not meant to be driven cold, thats why you get some laps in to heat them up. These are better at fade resistance because they are meant to operate at those temperatures. A street pad will not squeel when cold but will likely fade more if track driven. So it might be the pad rubbing against the caliper. I know that sounds stupid but thats why they give you a special lubricant you put on the back of the brake pad before you put them on. That way there is no rubbing which is the main cause of sound (besides the brake pad wear thing thats designed to make a loud noise when the rotor touches it).
