Old 02-12-2007, 09:48 AM   #17
porsche986spyder
Originally Posted by blinkwatt
I picked up the primer,paint and enamel you listed and went to work on some spare parts I had in the garage. I can't seem to keep the shiny finish that the paint has,it dulls after a few minutes and looks like it is VERY slowly coming back out. Could this be happening because it is only 30 outside,or am I missing somewhere?
The temperature could have allot to do with it. I did mine inside at 75 degrees. The last stage of the painting with the Rust-Oleum Crystal Clear should make it really POP! and VERY glossy! If you use several thin coats, it will look much better. But, If you apply it to heavy, it WILL look dull at first, but after a few hours will show the silver color though and should not stay dull and cloudy.
porsche986spyder is offline   Reply With Quote
