Try turning the key all the way to the left before starting. If this doesn't work then to the dealer you should go.
My Ignition was messed up then the dealer replaced it for me for $400. I could've lived with the faluty ignition as long at I manually turn the key to the left after the car started. The ignition switch costs less than $30, but replacing it is a hassel.
