Originally Posted by Chris_911
Many thanks Rick.
Car doesn't have PCM (and hence no DVD drive) so my installation sounds more complex, though the car does have the optional CD changer.
I think I will try to find an audio installer with the product and seek further advice.
Your install should be easy as you can tap into the back of the CD changer. (or just remove it). You just need to make sure that the Gateway 500 is 'upstream' from the CD changer on the MOST bus.
Only one of the CD changer or Gateway 500 can be used at a time. There is a switch on the Gateway 500 to select which device is active. Changing the selection requires waiting until the MOST bus is restarted (i.e. the next time you start the car)
