Old 01-05-2007, 01:52 PM   #2
racer_d
It's pretty easy, especially if you have the Bentley manual.
Basically - (insert any and all possible disclaimers about safety here) but.. remove wheel... locate brake caliper... remove "pin" and "clip"... may need to spread the calipers to loosen the pad... remove pad sensors.. remove pads. Insert new pads, apply sensors, replace clip and pin, re-install wheel.
* if you can't fit the new pads in because the pistons have closed up again, carefully spread them apart. Also, if your brake fluid resevoir is pretty full, be aware that when the pistons are "pushed in" it could push fluid out the overflow line. Brake fuid is very corrosive.
The manual will be very helpful with pictures/descriptions as needed.
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
