Old 01-03-2007, 10:44 AM   #3
EB847
I used a large flathead screwdriver wrapped in a t-shirt. Pull the trim back and use a flaslight to see where it is attached, then pry at that spot. I was able to re-use all the plastic molly type pieces to put back into place. Even though almost everything is expensive with a Porsche, I would think replacing those plasic pieces as needed at the dealer would be pretty cheap. Pry away, it's not that hard and you don't need any special tools!
EB847 is offline   Reply With Quote
