Originally Posted by blue2000s
If you are in gear, press the gas pedal and the engine speed goes up but the car doesn't accelerate, the clutch is worn. It's usually most obvious in higher gears first.
OK, this should be tell-tale sign of a very worn clutch. Are there any early warning signs?
