Hi,
      Replacing the cable isn't too difficult, but it gets involved.  Timing it is pretty easy - you'll need a ruler or gauge and a portable drill.
      Here's the procedure:
- 1. Open Top approx. 5" from windshield Header.  Remove Ignition Key to prevent accidentally triggering it.
 2. Remove Lower Ball Socket tensioning cable from L,R sides.
 3. Remove Fabric Flap at the Rear Panel (push downward at both clips).
 4. Fold rear of Top back until you feel it catch (for Glass window tops, use retaining strap to support glass).
 5. Use a screwdriver to remove Hard Tonneau Ball Socket from Transmission Drive Lever.
 6. Remove Drive Lever Mounting Bolt.
 7. Remove Drive Lever from Transmission and fold forward.
 8. Remove Plastic cover for Transmission.
 9. Remove Plastic screws holding foam insulation over transmission and fold back.
 10. Remove Transmission Mounting Bolts and pull Transmission out along with the cable.
 11. Remove Transfer Gear cover screws to remove cable.
 12. Attach new cable to transmission cover and loosely attach Drive Lever to Transmission.  Be sure to align the casting marks on the tranny case.  Use a portable Drill to turn cable to move lever if necessary.
 13. Remove Lever and reattach transmission to body (16 ft.-lbs.), reattach Plastic Cover and Foam Insulation.
 14. Reattach Drive Lever to Transmission Body (59 ft.-lbs.).
 15. Using a Ruler, raise/lower Drive Lever (using Drill) measuring from the pivot link to the Gasket for the Top Tonneau (195mm ± 0.5mm).
 16. Once both sides are equal, attach cables to Motor and reattach Tensioning Cable Ball Sockets on both sides, drop rear of Cloth Top and reattach Fabric Flap.  Carefully operate Top to check operation.  Caution - the Top Tonneau is Aluminum and will easily bend and crease if the measurements are not exact and equal.
      Hope this helps...
Happy Motoring!... Jim'99
