Old 07-27-2026, 11:52 PM   #9
997_986
Originally Posted by Toppy986 View Post
Thanks JFP I agree that the best wire connection is a solder one.
My reason for changing the connector is, when I first removed the connector from the sensor it was very tight and I may have pulled on a wire and broke one.
Would the car not idle with a broken wire when plugged into the sensor, stalling only occurred when sensor and in the air flow of the intake, engine idles when plugged in but sensor removed.
Thoughts?
For example, I need to replace the throttle body connector; I’ve snapped off a retaining tab. The wires from the old connector are unpinned using the appropriate tool. The connectors have small barbs that prevent them from being pulled out. These barbs are pressed in so that the connector can be removed.
I’d recommend doing the same with your MAF connector; that way, you can check the cables and their connectors in detail.
997_986 is offline   Reply With Quote
