Old 07-27-2026, 09:38 AM   #4
redpepperracing
redpepperracing's Avatar
If you need to replace the sensor connector, DO NOT USE CRIMP SPLICES, solder and heat shrink tube the wires. Over the years, we have had to redo more of these than I care to count to fix the problems crimps create...................
Interesting. Most people swear that crimp connections are the only thing that should be used in automotive applications. I am about to build some O2 sensor extension wires, the connectors that come with the plugs are crimp style.
And not trying to hijack the thread, I think the MAF connector is the same or similar to the O2 connector.
2000 Guards Red Boxster (check me out on Elferlog: https://www.elferlog.com/porsche/2000-986-boxster-2-7/72ec5afa-b31d-486c-a43f-8581530473d8)
2014 Meteor Gray Cayenne
redpepperracing is offline   Reply With Quote
