Old 07-08-2026, 04:59 AM   #1
newBgeek
6 speed manual can't shift past 2nd
Hi Gurus. My 2001 Boxster S got into a situation where neutral got jammed so I couldn't shift past second . I found that the issue was a metal sleeve on the cable popped out and jammed against the end of the cable. I managed to push it back in to the point shown in this photo.
That worked for a couple days but it popped out again. Did this break internally or didn't I push it in far enough? Is the permanent fix a new cable?
Sent from my SM-S921W using Tapatalk
newBgeek is offline   Reply With Quote
