Old 05-15-2026, 01:32 PM   #8
elgyqc
elgyqc's Avatar
Going in from the frunck I got the front blend door out... it was still almost fully clothed in foam, that was falling off. The foam was on both sides, as others have indicated and I think even folded over the edges. So, doing the repair with tape or an aluminum patch as I am doing means that there will be leakage around the door where the foam should seal it. I am debating whether to add foam around the edges to get a factory like seal. Probably not...
Grant
