Old 11-06-2025, 11:55 AM   #14
Bradders2175
Originally Posted by A8ked View Post
The large rear window and defroster are a big plus for rear visibility and cold conditions. There are two small caps that fit onto the hardtop front guide pins, if you leave them off you will get rattles. The caps are easy to lose when removing or installing the top, but replacements are available. As others have said the three top latches are adjustable and hold tightly.
Hi,
A late response I know, but I recently bought a hard top and had no idea about the caps you mention. Can you post a photograph?
My roof does fit well, but I did adjust the three H5 bolts on either side by the locking handles. That gives vertical and lateral movement so it seats better.
Regards,
Paul
Bradders2175 is offline   Reply With Quote
