Old 07-04-2025, 07:18 AM   #2
husker boxster
husker boxster's Avatar
Originally Posted by bcrdukes View Post
Wow, thanks for sharing! 3 seconds shaved off from a gearing strategy is awesome!
Yes, and the previous record was set last year and was 3 sec better than the old record. I attributed last yr's leap to being faster in several corners. T3 is an 'instinct survivor' corner where your survival instinct kicks in before your bravery does. I started to take that corner in particular a bit faster. It makes sense I would be faster this yr with the short shift since it dropped me back into peak torque range rather than 1K rpm above it. Seems like the final 1/3 of every straight puts me in the gray zone debating whether to shift or stay in the same gear. I tend to stay in the gear and save 2 shifts on the clutch and trans.
I am curious which tires these are and how old are they?
My tires are / were Bridgestone Potenza Sports. They are a little less than 2 yrs old with approx 6K mi and 5 DEs on them. I have camber at -2.2 frt, -2.0 rear. I normally get 3 yrs out of my tires w/ 3 DEs / yr. This was my first set of Bridgestones and I wasn't impressed. I would list them behind the Mich Super Sports, Conti Extreme Sports (not 2), and Yoko Advans I've previously run (and in ranked order).
I'm not sure if maybe I caused some of the damage to this set. I normally chase pressures and measure to a pressure after each session. I did that on Fri, but it quickly got to 100 on Sat and only bled after the 1st session. I knew I wouldn't be cutting any quick laps at that pt so I didn't cont to bleed air. That might've caused too much heat in the tires and blistered the edges. I plan to talk to the other 2 ppl I know who blistered their tires and see if they were chasing pressures or not.
My tire strategy in the past has been to buy a premium tire that's low priced. The Yokos have really fit the bill of being a good street tire for mileage and a decent tire for the track. I've had 2 sets, buying the last set for $750 before installation. PS4Ss were around $1200 at that time. The Super Sports I had many yrs ago were the best tire but I don't see the advantage of 2-3 seconds / lap when I'm going to tear them up in a short period of time. I can buy 3 sets of Yokos for the price of 2 Mich. Going thru my 'broke yrs' where I was unemployed and just living off a small pension and savings, it made a difference.
But I recently started Social Security and have a little more discretionary income (but also rebuilding my savings), so more options are available to me. The PS4S is on its last leg before the 5 is released, so this might be the best time to buy a set before the higher priced 5 comes out. The PS4S is on sale for $1350. My 2nd choice would be the Conti Extreme Sport 2, which is new technology. My only reservation was yrs ago I had the Conti on 2 different Caymans and both sets cupped on the front. I don't see anyone mentioning that in the comments where I did on the originals. 10 yrs is a lifetime in tire tech, so maybe they've solved that problem. Contis are $1230. Or I could cont with my current strategy and get a set of Yokos. With rebates they can be had for $940. Need to decide today.
1989 928 S4 5 spd - black
