Old 07-01-2025, 03:29 PM   #3
elav
Originally Posted by Marc_986 View Post
I would replace the bearings as well while you have it all apart.
Other things to consider:
- The sway bar end link might not come out in a good shape. Either have new ones before you start or be prepared to take a few days longer if you need to order.
- The struts have a small clip to which a cable attaches. Old ones tend to break.
The front struts are the easy ones.
If you are doing your swaybar drop links might as well do the swaybar bushings too.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
