Old 05-08-2025, 09:38 PM   #2
pilot4fn
The oil level is very important to be right. On 5-speed, the level should be 11mm below the fill plug lower edge.
If the oil is overfilled, it is fairly common that some transmission oil seeps thru the oil seal at the transmission input shaft to the clutch bellhousing. On the bellhousing is a lot of opportunities to collect the small amount of oil before it leaks down to be visible.
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
