Old 05-06-2025, 09:04 AM   #566
LoneWolfGal
LoneWolfGal's Avatar
Almost, but not quite. You definitely want a dot of blue Loctite on the threads of both the pressure plate and flywheel bolts, but a coating of this product underneath the heads of the flywheel bolts makes cranking them to their final +90 degrees after torquing one heck of a lot easier.....
Makes sense.
Also, you've convinced me that, after sparing no expense on the IMS bearing, I'd be nuts not to cough up a couple hundred more for factory clutch parts. I keep imagining the clutch giving out on some godforsaken stretch of road and wishing I had.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
