Old 04-16-2025, 08:26 AM   #1
JFP in PA
Originally Posted by Lacostas View Post
true.. What's the next thing to check ? Maybe the Regulator cant "see" the correct voltage of the system due to a bad ground ?
1. Bad starter ground, even though car starts perfectly fine
2. Bad alternator mounting ground (where it bolts) ?
3. Other ECU/electronics ground im missing ?
Any other electrical side worth to check ?
If you suspect that you have grounding issues, run voltage drop tests across all the grounds.
