Old 03-26-2025, 09:38 AM   #409
LoneWolfGal
LoneWolfGal's Avatar
Sorry I didn't read this before you went out and bought more tools, but probably the reason they suggested a 'zip' driver is because it makes sudden impact bursts which could jar the nut into turning without the stud, same way using an impact gun on a wheel lug will not cause the entire wheel to turn like it would when using lug wrench. You could make your own "impact" by simply putting a ratchet on it and lightly tapping the handle with a hammer. Then once you're comfortable that it's properly seated and turns you could troque down to spec.
Jake Raby replied to my trouble ticket:
"Piper6909 in the thread is offering some good information. Usually when this scenario occurs the threads of the stud, or the nut have debris or burrs creating this instance. Heavy lubricants can also lead to this when applied to threads. With all the assistance on the thread you have what you need to move forward. The trick that LN advised may seem unorthodox, but it works and does so without any detrimental impacts."
Al, since I don't have a pneumatic zip gun, I'm going to try my powered ratchet and maybe the old-school impact hammer method you suggested. The crowfoot set and bench grinder won't be here until tomorrow anyway. I'm not sorry I bought them. You can't have too many tools. I plan to pick up the set of pass-thru sockets JFP recommended.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
