Old 03-26-2025, 03:51 AM   #19
piper6909
piper6909's Avatar
Sorry I didn't read this before you went out and bought more tools, but probably the reason they suggested a 'zip' driver is because it makes sudden impact bursts which could jar the nut into turning without the stud, same way using an impact gun on a wheel lug will not cause the entire wheel to turn like it would when using lug wrench. You could make your own "impact" by simply putting a ratchet on it and lightly tapping the handle with a hammer. Then once you're comfortable that it's properly seated and turns you could troque down to spec.
piper6909 is online now   Reply With Quote
