Old 02-20-2025, 05:14 PM   #8
Cdeboer
What I see in the pictures is that you have the ECU from the 1998 and the ECU from the 2000 S. If the wiring harness has not already been modified, it would probably be best to get an engine harness from a 2000 - 2002 engine along with a throttle body. *The tube from the Air Oil Separator will also need to be modified to connect to the '00-'02 throttle body. With that, the 1998 engine can run in the 2000 chassis with minimal modification.
1997 - 1999 Boxsters have a mechanical throttle cable to control the engine. Your car does not have a throttle cable visible in the pics. The 2000 model does not have a throttle cable to control the throttle body because the 2000 and later models use an electronic throttle.
I don't see a tube going from the air filter housing to the throttle body. The missing tube should have the Mass Airflow Sensor.
It's going to take some 'hacking' skill to get this to work, but it can be done.
Awesome thanks for the help now I have a good direction to head in been a big help.Thank you
Cdeboer is offline   Reply With Quote
