Old 02-12-2025, 04:59 PM   #1
spinjockey
This is the battery vent hose. There should be a port on rather side of your battery. The positive terminal cap should have come with a plug to block off whatever side you don’t connect to the hose. You do need to hook up the vent because lead acid batteries vent gas while charging and those vapors can and do build up leading to corrosion.
spinjockey is online now   Reply With Quote
