Old 01-07-2025, 10:32 AM   #5
Marc_986
And you shouldn't pull it apart again as you'll pull the wheel side inner race out of the bearing.
Unlike many bearings we encounter, these wheel bearings are angular contact bearings. I am not surprised you would feel movement without the stub axle being tightened. Torqueing up the nut will press both inner races together and only then should there be no play.
Marc_986 is online now   Reply With Quote
