Old 01-07-2025, 06:59 AM   #4
elgyqc
elgyqc's Avatar
When replacing ball bearings you always have to be sure that the force applied does not pass by the balls. So pressing the bearing into the carrier the press must only be on the outer race. Inversely, when the hub is pressed onto the bearing the force must be on the inner race only. It is not clear from your post whether this was done properly.
Grant
